Bruce from Ontario
Started to rebuild the engine yesterday removed fuel pump last weak and sent away with injecters.report one broke cam spring 4 bad injectors.removed pistons today #4 pist in #2hole 2 in 4 ; 1 and 3 where right .piston 3 @ 4 had one broken ring on each . must have been a back yard fixer do the work
question #1 the engine counter balance inside was not lined up with timing marks we put are own marks on before removel.should i reinstall on factory marks or my marks and at #1 tdc or does this matter.
quest #2 rotary fuel pump install on dowel at #1 tdc pump gear turns 2 times to crank shaft 1 time how to tell if your right or 180 out of time.
