TRAVELING SPRINKLER- WATER REEL
beanman
has anyone had any experience using a small water reel. like a kifco b110 or rapid rain 860? tanks for any input.
I don't know about these units but years ago I watered my large lawn with a very similar unit called a "rain train". Same principle, it followed the hose that you had layed out, except it drug the hose rather than putting it on a reel.
Worked for years, problem free. Not sure what ever happened to it, or if they still make them.
I think sprinkler systems for lawns hurt their sales.
the ones I mentioned are water driven. they have 200 ft. of hose on a cart. I need one to water 3 acres of sweet corn.
Have a talk with the greenskeeper at the local golf course. The average par 5 is a little over 3 acres. See what hwe would do. You'll just have to use some 5 foot risers on the sprinklers.
I run four sprinklers, two at a time on 8 foot steel fence posts. Above ground vinyl irrigation hose. It all gets put in after the corn is planted, out after harvest.
Right now I use a tripod sprinkler, but I have to move it every 2 hours or so. would be nice to have one that would run for 8-10 hours and shut off at the end.
We have used a Bauer Rainboy reel pull for 20 years on 20 acres. 2.5 hard hose sprinkler is a Nelson 100 Big Gun covers 150 ft wide. In hot dry condition. run 24-7 run unattended except for reseting. Going to change to a Boom for it. More efficent. Excelent for odd shaped field. Wind ruins watering pattern.
Ou Rainboy has 600 ft of hose cover 1.5 acres per pull. get three pulls per 24 hr. applying 2 inch of water.. All depends on your water supply, pump. It needs to be engineered not just thrown together. We drilled a irrigation type well twenty inch bore eight inch casing, gravel packed, Stainless steel submersable pump.
raise ten ton per acre of Alfalfa per acre.
I can't go bigger than 3/4 -1 inch line.I have a 3/4 hp main pump with 55# pressure. I have a booster pump to up the pressure to 80 psi. only have about 10 gpm. the field is 450 ft. to the other end, so I probably loose some pressure, that' why I need a smaller water reel.
(quoted from post at 16:43:21 01/13/12) the ones I mentioned are water driven. they have 200 ft. of hose on a cart. I need one to water 3 acres of sweet corn.
ever used one like you are asking about, but I do have the rain train mentioned above, and they are great on grass, but in tilled ground such as a garden they just bury themselves in the mud.
