830case fluids
Anonymous-0
can anyone tell me what type of fluids go in a 830 case? it's a 1961 model. the reason i'm asking is that i've heard said that in some of the older tractors they use to use mineral spirits due to it being thinner. if this is true, i know it didn't go in the crankcase, but maybe in the transmission and/or hydraulics. i've been using transmission/hydraulic fluid in the transmission and hydraulics, but was wondering if a thinner fluid might give better results. the 830 case has a wet clutch? i'm just wondering. Thanks
If it is case -o matic use Case hy tran or dextron 3 Rear end takes 80 wt,,Hydraulics take any 10 weight oil s ,,
