littleschnebs
Hi, I have a 4320 John Deere. The pto quits working as well as the power steering when I hold the clutch in for approx. 20 seconds. When I let the clutch out everything is back to normal in 1 to 2 seconds. The next thing is when I turn the steering wheel back and forth and raise the three point, the three point chatters and vibrates as it slowy comes up. The last thing is the pto slips under load. The pto is brand new so it can't be the clutch or pressure plates. I have changed hydraulic oil and filters, and have checked the cyndrilical screen for the hydraulics also. It sounds like the hydraulic front up front is chattering a little, but it always has. The problem is getting worse and worse. Has anyone else had a problem like this and found a solution? thanks
