Mike Henry
This may sound foolish to you fellas but I need a tutorial in putting on a second set of rear weights on my H. I have the 1st set on, flat surface nearest the hub.Should that be turned around to put the second set on? Am I correct in assuming that the bolts go through the holes on the first weight and then into the aligned slots on the second weight? Wanted to install the weights so the ole girl could get a little better traction when pushing snow. May be a mute point as we dont have enough snow to cover my shoe at this point. But just in case I want to be ready. Thank you in advance.
