Dave from Mn,that Meyer spreader
rrlund
Dave,I missed your post yesterday,but STAY AWAY from that spreader for that kind of manure! I hauled mine top the crusher a few months ago. Those are best in liquid and that's ALL. I wore the back end off of both augers,literally broke right off. Those rear carriers are just fiber bushings and need liquid to lubricate them. Mine wore right through the steel and cut them off. Even with a fair amount of liquid,like feedlot manure,when you get a wad of dry hay from around the feeder,it will roll on top til the liquid is gone out the bottom,then it jams the whole bunch in to that small door and slips the clutch. Only way to avoid it is to tighten the clutch up so much that it won't slip,then you'll constantly be fixing those 120 pitch roller chains that run the augers.
I can't even begin to stress how much you need to keep looking and find a good box spreader instead. If you buy that Meyer,you'll find out on day one that you should have taken my advice. That's NOT the spreader you're looking for. Trust me!
Dave : RRlund is very mistaken about these Spreaders. They have very heavy augers and with the third auger to roll the manure back toward the front they work great. Also I stated you need to be looking a the V-Max model they came out about 7-8 years ago the rear opening is much bigger and the augers supports are bronze bushings not plastic. Rrlund must have used an older model that had the small rear door and did not have the augers supports. Also the third auger is an option that you need for pen pack.
I have one of these that I use every week. I load pen pack that is three foot deep into it. I also clean up around my hay feeders each spring. It does a much better job than a side slinger spreader. Much simpler spreader.
Take a look at this link to the current model spreaders.
Meyers V Max spreaders info
