tractor radiator leak
On my 706 Gas tractor I have a small leak towards the top of the radiator. Is that radiator stop leak stuff ok for a fix or should I pull it out and have it repaired? Pros and cons of each is appreciated.
Matt
If it's a working tractor, I'd get it fixed; otherwise............ otherwise. I assume it's not or you wouldn't be asking a bunch of crackpot strangers for advice. :>)
(quoted from post at 07:55:03 12/27/11) On my 706 Gas tractor I have a small leak towards the top of the radiator. Is that radiator stop leak stuff ok for a fix or should I pull it out and have it repaired? Pros and cons of each is appreciated.
Matt
Silver Seal is inexpensive enough that it is definitely worth trying. I've had very good results with it myself.
Pros for pulling it off is it's done right and you get a paint job to boot. Con, cost.
I think mine was around the $125 mark to have two or three cores repaired, pressure tested and cleaned out and painted.
I'm not a big fan of leak additives.
I'd pull it and have it patched if you can do without it for a few days. Using anything to seal it from the inside plugs the core and you'll start running hot. Trust me on this one. Voice of experience.
Here's a pic of what I think is bars-leak that accumulated in the thermostat housing in my old jeep.
If it is not a big hole a box of pepper ,yes pepper will seal it up with no core plugging. I have done this several times. Now it would really be best to pull it and have it fixed right. The pepper would get you to a warmer time frame if that is the issue.
The hard part is finding a GOOD radiator shop.
Most shops these days will tell you that radiator is a lost cause, even with such a minor leak. They will sell you a new radiator, or nothing at all.
(quoted from post at 08:34:39 12/27/11) good answer
Silver seal is about $3 per container, and it'll probably take 4 containers for that 706, so $12 compared to about $500 to $600 for a new radiator.
If you try some kind of stop leak only one try! Most of the problems you see with it plugging a system is repeated applications. Problem with used stuff is you have no idea how many times it was done before.
I know how to fix a radiator so for me it's no problem, I pull it and fix it. If it's a worker and not a shower I'd lean toward doing it right the first time.
Rick
"Pour int the rad" fixes are for emergencies just to get you home. Or to get the crops in or off.
Only solution is to pull the rad and repair/replace.
Odds are the old rad is rotten due to oxygen entering through the cap and depleting the coolant's corrosion inhibitor.
Mine is a 1964 model. One year ago had the radiator off to replace water pump. It had a small leak at the throat. Took it to shop for fix. Got fixed, painted and pressure tested --$60.00, and He gave me a pocket knife. Very Happy with results!!
My John Deere 70 was leaking water faster than I could pour it in. I put some pepper in it and it stopped immediately! Ran it the rest of the year and then drained for the winter. Come spring, I filled it with anti freeze and poured in some more pepper. It's been 3 years, no leaks. Yes, I use it, plant, spray and take to shows. Chris
The last radiator I had repaired (15 years)the fellow talked me into removing the top and bottom part and putting new in place of the working part. It was a Ford 8N and the cost was $165.00. I picked it up the next day and thought I had made out like a bandit. ohfred
Talk to a few of the local guys and find a decent radiator shop. Most of them can repair and test a radiator and repair it in just a few minutes. If it's totally shot, many can pull the tanks and recore one fairly quickly. They're cheap in comparison to what a new one is.
Ill bet you have a radiator problem that caused the leak at the top,Mostly cloged radiator,It probally could use a good rodding out.My neighbor who has a RAD.shop is shutting down after 50 yrs,hell be missed
jimmy
(quoted from post at 15:55:03 12/27/11) On my 706 Gas tractor I have a small leak towards the top of the radiator. Is that radiator stop leak stuff ok for a fix or should I pull it out and have it repaired? Pros and cons of each is appreciated.
Matt
Since its a haying tractor I will go ahead and tear it down and fix it correctly then. Have another to chore with so I have all winter to do correctly.
Thanks guys for the replies!
By the way, I rebuilt the radiator on my 806 when I had a problem with the water pump seals, and it's an easy take out- hoods, two bolts, loosen the hoses and and it slides right out of the top.
