converted FIL's 9N to 12volt (DONT send 10 pages of why not to convert). Old generator was bad and he doesn't like to fiddle with things and i had an extra alternator.
QUESTION: Has anyone had trouble with lower RPM tractors not getting enough RPMs to excite the alternator. It is a 3 wire DELCO and is wired properly.
Seems like the tractor "should" turn fast enough to get the unit to charge with it rev'd all the way up.
Has anyone had to "re-excite" a 3 wire alternator (GM Delco)? If so how do you do it. It has a wire to the idiot light and ignition switch from #1 and #2 terminal to the "BAT" term on the alternator.
Thanks!!!!
Thanks!!!!
