Sounds like the grinding noise I have talked about earlier as coming from the rear-end is actually coming from the transmission. I have removed the tire and brake, the brakes look good, the axle seems fine, when turning it it doesn't grind and seems to be ok. The u-joints are tight and there is no play in the drive shaft.
So that brings me to the trans mission. Fluid level is fine, doesn't smell burnt. Noticed when you here the grinding sound the loudest is when putting back into park, seems like even when stepping on the brakes, the transmission is still turning the drive-shaft. It is like when you don't let the car come to a complete stop and jam the car into park.
Could it be something to do with torque converter.
If you have any questions let me know, your help is appreciated.
