Dave from MN
Had the whole pto rebuilt last spring. Not sure what is all in there but was sent in because it would not shut off, so I am assuming a brake, and clutches. Respectable mechanic. Well , have not used the pto, other than to run an auger for about 15 minutes. Now it does turn whenit is supposed to be off, shut off tractor, hooked up to round baler. Some times it turns it, then all of a sudden it will, when the lever is in the disengaged position. Tractor was NOT in Reverse when PTO was ran that 15 minutes. Any ideas to check? Is this common in coler weather, or should I call and demand some warrenty work?
