Paulson Loader Seals
Booker
New User
Does anyone know where I can find some seals for the main lifting cylinders of a Paulson Loader. I called the phone numbers that I found for the Paulson Company but the number has been disconnected. Does that mean that Paulson has shut down?
The rod on the cylinder has a diameter of 2 1/4"
Thanks for your help!!!
Sounds like you know the inside Dia. for he rod just need to measure the outside of the seal . NAPA should be able to help you. If not go to any good Hyd. Shop & they should be able to help.
I tried that number. It is a metal Fab shop and the guy did not know anything about the Paulson Co.
Try the number I sent, I believe they can get everything from parts to a entire new loader, the Company that has the rights is somewhere around Rogers/Elk River Mn, you can still buy a complete new loader, as of 2010??
I always take the old seals to hyd shop , they match them up . Never had any problems yet . Imagine the original company gets the same seals .
Do you have single acting or double acting cylinders?? I may have the seals for the single acting cyls, I know for sure I don't have the double acting ones. I will look in the morning.
About an hour from you, west of the cities by Delano. I should have the right ones, 2 1/4" inside, 3" outside, they are cup shaped, give me a call, 763-479-2928.
Just called the number you mentioned. I talked to Steve and will pick up the seals this afternoon. He said they are located in a building with the sheetmetal fab shop. The guy I talked to in the fab shop must not have known about the Loader business.
Thank You for your help!!!
