Plows and plowing
Nebraska Cowman
If you are interested in plows and plowing, either for fun or in competition, I have started a new forum on my site specifically for plows. I do not to pull anyone away from YT but think that like the cornpicker forum this could be a great idea to pass on information.
Plows and Plowing
I had that problem also.Tried 2 different passwords that I use both with enough letters.Something must be wrong.I will try again later as it sounds like a good board.
Vito
The board called for I think at least 6 letters, at least one upper case and at least one number. I have found that helps keep bots from registering but it does make it more complicated for real users.
Thanks.Got registered.Shouldn't have tried it first thing in the morning.Eyes are still a little blurry.
Vito
My password went good but I can not register my user name(they say it is invalid) and I can't get any information about what is wrong. Now what? Armand
Steve may be taken but Delta Red or DeltaRed should either one work. Unless you have registered under another name with the same email. The system won't let you register 2 accts under the same mail
Has that changed? When you first started the board you got me in and set up with the same user name and password that I us here and there is no numbers in it, just the letters in my name? Just checked it after you put on this post and it said I had not been on for close to 3 years. How time flys. Thought it was about a year.
