560 drawbar attatchment
jim1960
New User
New here, just bought a 460 Farmall gasser and was
wondering if a 560 3 point draw bar atatchment would
fit my 460? Thankyou
I think we better define what it is you are asking here, there is a lot of grey area.
Are you asking about a drawbar (bar with 7-11 holes in it) that fits on a 3pt?
Or are you asking about an attachment, like a disk, 3pt blade, mower, etc.?
Or would you be talking about a drawbar that fits under the belly of the tractor & not really part of a 3pt?
I'm sure others are smarter than me & understand, but I'm not quite sure what exact piece of iron you are talking about? So if you could humor an old dull guy.....
--->Paul
If you are asking whether a three point aftermarket hitch from a 560 will swap onto a 460, the answer is yes and there is no modification necessary.
That hitch will fit a bunch of tractors starting with the H and M models provided you have the axle brackets for the original horseshoe drawbar.
your right i was useing the discription that the seller was useing. i have the fast attach system. and what i saw for sale slides into those 2 point sleeves with the latches and then u have the bearing that slide onto the implement pins and then it also has a place to hook the top adjustable coppler. sorry i know my names of items is not correct but hope i cleared it up a little bit.
Ah, the converting arms from the IHC Fast Hitch to make it into a 3pt hitch.
Sorry, I don't know the answer, but yes you cleared up what it is you are asking.
--->Paul
(quoted from post at 22:33:46 11/01/11) your right i was useing the discription that the seller was useing. i have the fast attach system. and what i saw for sale slides into those 2 point sleeves with the latches and then u have the bearing that slide onto the implement pins and then it also has a place to hook the top adjustable coppler. sorry i know my names of items is not correct but hope i cleared it up a little bit.
Jim, if it fits on a 560, I would be almost certain that it will work on a 460. Just ain't that much difference between the 2.
