Need some direction on where to look.
As the subject says. It is a 1988 chevy 1500, 5.7 automatic with throttle body injection.
The problem is at slow speed it will blubber,shudder. Once it gest a little more throttle it will level out and run pretty decent.
If you are just sitting still, it will idle, just when you try to ease into the throttle it will buck,snort and run crappy. Get it out on the road and it will run pretty good at highway speed.
I have replaced the coolant temp sensor as the old one was not reading the right ohms at temperature.
Really would like to figure this out, any help would be appreciated.
