John Deere 5220 has noisy power steering
rogerd
I have a JD 5220 and the power steering is really noisy. I looked for a place to check the fluid but can't find where to check.
Any information would be great.
The power steering is powered by the hydraulic system and is not a separate reservoir. It is common for them to make noise when it is real cold and have just been started. If it is doing it now than I would change the hydraulic filter first. It maybe plugged and it is right under your right leg. That can make the hydraulics seem noisy when ever any oil is used.
If it still makes a noise then you may have a high pressure internal leak. This would need to be checked out by some one familiar with how to repair these tractors (dealer tech).
