NEED PART BAD 3045109R2
L J DAVIS
New User
I AM IN SERIOUS NEED OF A (SPOOL, SPACER) FOR THE HYDRAULIC, 3 POINT CONTROL VALVE FOR AN INTERNATIONAL MODEL 2424. IT SITS DOWN IN FRONT OF THE SEAT AND MINE IS MISSING INTERNATIONAL PART NUMBER 3045109R2. PLEASE HELP ME, I AM DESPERATE !!
PART NEEDED
A few other tractors used this part also. If you are looking for a used one you can look for these other tractors also:
354, 2300A, 364, 424, 2424, 444, 2444, 384 & B-414.
Lots of these tractors up here in Canada. Try www.fawcett.cc or www.chowntractorparts.com
Tim:
You must have a parts book and interchange to know what else it fits.
I understand the IH parts number system, I used to be a parts manager. The R2 on the end of the parts number tells me it is a one piece item rather than an assembly.
If he can't find it, I wonder if the specs can be found to machine one. DOUG
Doug, I have a set of Case-IH where used microfiche. One of the best purchases I made (along with the microfiche machine) for finding used parts. Helps to expand a search for parts quite a bit.
I am Desperate, Sorry for all capital letters. I was in a hurry. Winter is comming fast to Mi. I do not want to work on this tractor in the cold. Getting tooooo old for that
(quoted from post at 18:28:07 10/21/11) I can't help you with your part.
I can help you with forum decorum.
Don't type in all capital letters.
Good luck in your search.
nother little piece of forum etiquite is to either answer/help with the OP's ???/problem or just keep quiet and move on.......
Or is there a rulebook somewhere that says which case to type in?????
