pick up water pump removal
northvale
OT, got a 89 F250 pick up. Water pump is leaking so I tried to get the old one off. Every bolt but 1 broke off flush with face of water pump. Pump won't budge either. What is best way to get pump off then balance of bolts out? I am thinking drill a couple 1/8" holes along side all rusty bolts in the pump then squirting in PB blaster. Hammer pump lose. Thoughts?
Good luck ,,those are a bear ! I have taken small drill bit and went around broken bolts then sprayed PB , or even Lime away toilet cleaner . Air hammer sometimes jars them loose . YOu may need new cover depending how badly it's rusted. Ford should have new bolts in stock , aftermarket may have them also .
most the time the bolts are stuck in the pump
& the frt cover, I've had to cut the pump with
a cut off wheel, But You got to becaureful not
to hut the frt cover,, I am assuming it;s a 302
or 351W?? Lotts of penatraiting oil!!! & a Hammer
Sounds like an aluminum pump body corrodded on to steel bolts.Get a can of Kroil and give it time to seep in.Aluminum on steel has been trouble since the early 30s with Ford, they never learn.
(quoted from post at 06:12:51 10/19/11) Sounds like an aluminum pump body corrodded on to steel bolts.Get a can of Kroil and give it time to seep in.Aluminum on steel has been trouble since the early 30s with Ford, they never learn.
LOL Nope they learned......that the customer will buy anything!
Rick
Had that happen on a chevy i was working on. Used a propane torch to heat the bolt and surrounding metal a bit then grabbed each with a good set of vice grips near the block. They turned out fairly easily after that. If that doesn't work, the best rust penetrant I have used is the Dodge brand. It is some fantastic stuff and I have used all that have been mentioned on this site.
Leonard
Thanks. Drill bit idea seems best bet. Once pump is off, then I work on remaining bolt lengths with heat and more PB Blaster.
