Matt Jolly
New User
I just got a little VAI with a belly finish mower a couple weeks ago and it runs but really likes the oil and to smoke, i was wondering were the best place to buy a overhaul kit was also the cheaper the better i only have 250 bucks in it and would like to keep this as cheap of a project as possible. thanks in advance Matt
The difference between "Cheap" and "Quality" is:
"IF YOU DON'T HAVE THE TIME TO DO IT RIGHT....
WHEN WILL YOU HAVE THE TIME TO DO IT OVER?"
What oil do you run in it?? More history is needed to be able to help you much. If your running say a 10-30 switch to a 20-50 and see if that helps. Also if it sat parked for say a year or more before you got it do a ATF treatment to it and that may help. ATF treatment is simple put a 1/4 cup of ATF in each cylinder and let it sit a couple days. Start it up, you may need to spin it over with the plugs out to keep from hyd locking it but I would try it with out doing that because that would tell me if the rings are in fact bad.
