(quoted from post at 12:05:20 10/02/11)
The injection pump itself is timed to the engine, so if the pump is designed to deliver fuel at say 2° BTDC (injector needle lift is just beginning). If the lines are shortened, the fuel will begin to lift the needle 8° BTDC. Now this is messing the pump to engine timing up. If the injection line is lengthened, the amount of time for the displayed fuel to move down the injection line might cause the needle to lift 10° ATDC.
Imagine 2 garden hoses, one 50' and one 75' long, both filled with water and baking in the summer sun. Both nozzles are opened at the same time. Which one will get the cold water (out of the well) first (facet pressure being the same)? The shorter one will see cold water first.
Did I answer the question? If not, please let me know. bob
