M Carb inside nut!
Wayta
Tell me, how does one loosen one, or tighten -just tell me either and I will reverse the instruction for doing the other. I just need to know what tool you use to get any turn on the nut for the M carb inside.
As I have told others, ask a question on this forum and you will have an answer within 15 minutes. So, Thanks much, Owen - and even a pic!
(quoted from post at 17:42:19 09/23/11) Tell me, how does one loosen one, or tighten -just tell me either and I will reverse the instruction for doing the other. I just need to know what tool you use to get any turn on the nut for the M carb inside.
M Farmall? Only nut inside an M carb is actually the metering stem. I use a deep well socket.
(quoted from post at 09:22:35 09/24/11)
That is what I thought at first reading too until I realized that he was talking about the inside, next to the engine block, mounting stud/nut.
(quoted from post at 08:20:39 09/24/11)
A common 9/16" box end wrench works well on that inside nut. Granted it will be short stroked, but unless something is messed up, it only takes a couple of strokes and then it will turn off with your fingers.
