Indiana Ken
I have a wagon running gear with a small dump bed from an old truck mounted on it. The tractor PTO is used to run the original pump to dump the load. I have been using it the clear some rocks and concrete debris long ago dumped in the woods.
My question is what pressure should I run in the tires. It has 7.00x14.5 - 8 ply tires. The previous owner run 100 psi however on the road it rides likes it has steel wheels which cannot be good for the wagon gear. I have lowered the presure to 65 psi which supports the load without squatting and rides much better on the road.
Is there a rule of thumb based on ply rating?
