Posted this on a VW forum, but usually get better help here.
Daughter's car. She has an issue where the car suddenly started running pretty poorly. Engine stumbles at idle as well as higher RPM and is short of power. Nursed it to my driveway and read codes and all I get are error codes. CEL is clearly on (sometimes flashing), but reader does not recognize it as on and can't reset. Had one code indicate a cylinder 3 misfire so went ahead and put coil into it as well as plugs/wires. No help. Codes are meaningless only indicates something like "ER - no definition available"
Could the ECU have failed? How would I tell?
Thanks,
Kirk
Thanks,
Kirk
