Muncie hydraulic pump ID
Rick Kr
Just picked up an older truck with a muncie engine mounted pump.
It has 1 suction line, and 3 pressue lines. Is there an ID plate somewhere on the pump?
Combed through muncies webpage real quick, didn't find a pump that looked the same as mine.
Thanks
Rick
Does the pump say on it Muncie??? I have never heard of or seen a muncie hyd pump. I have seen there transmissions but all the pumps I have seen on there where other brands like Prince etc
Good question. I assume its a muncie pump. The switch in the cab for the electric clutch says muncie power products.
But, on the pump under the hood, there is not an ID plate that I can find.
Rick
I assume by your statement that it has a switch inside the cab and that your unit is a belt driven electric clutch unit.We used Muncie units on Tow truck applications before hotshift pto's for automatic transmisssion beacame common.I have never heard of the 3 pressure lines myself (which means nothing)I would suggest to find the nearest Muncie dealer or distribotur and send a photo and ask for their help.I am from Ontario Canada and we have a pretty good distriubutor here called Drive Products i Missasauga Ont.If I can help let me know.Ron
