ohiojim
have a 1952 farmall super M,..looking for a carb kit,..parts supplier on this site lists 2 kits....and i can't find any numbers on my carb,...any ideas..
The numbers you need are on a small plate on the back side of the carb if it is still on the tractor and then only way you can read the numbers is to remove the carb from the tractor
(quoted from post at 12:47:44 08/26/11) The numbers you need are on a small plate on the back side of the carb if it is still on the tractor and then only way you can read the numbers is to remove the carb from the tractor
No it isn't. The small, round, brass disc is located right where you can see it, just above the idle speed adjusting screw.
i still see no plate or anything that resembles a part number....on the bowel is L F
1
on the upper part that hooks to the governer is L F....will this help in etting the right kit??
(quoted from post at 16:23:08 08/26/11) i still see no plate or anything that resembles a part number....on the bowel is L F
1
Either the tag is gone or it is hiding under some crud, and my bet is that it is hiding. Do you need a whole kit, or just the gaskets? If you need a new choke shaft and plate, those parts are not included in any aftermarket kit.
