O.T.Carry permit in wisc.
philWi.
New User
Thought twice about asking but what the heck.Throw caution to the winds.I have a Armi tan Guseppe Mod Gt 27 /25 dcp .Does any one here have a parts manual for one? I carry it on occasion with out a ccp from Wis. Thinking about going legitimate and go for the permit. Parts manual isn't in print this late but would appreciate one so I could order parts for it in case some part fails. Thanks in advance. PHIL.
Your state may have some provision for taking a hand gun legitimate . Check first. I know a guy who did that and carried it into the sheriff's office in a bag and placed it on the counter. They were not at all happy with him. They said leave it in the car, we'll come out and get it.
You aren't going to find much in the way of parts for them unless you stumble upon a gunsmith who has a broken one in a box somewhere.
Numrich lists magazines...
http://www.gunpartscorp.com/catalog/Products.aspx?catid=2100
I had the larger one a few years back in 380, I broke the firing pin. I couldn't find one anywhere, and ended up making one.
If I were looking for parts or a manual i would try a call to EAA, they were the last importer I can think of for the Tangfolios(their Witness line).
Thanks to all.!!!!!Pictures is exactly what I have.
The part that is defective is the small shaft with the carrier,located underneath the barrel,as shown in the photos. Had some threads left on the shaft, but when it was fired, the threaded shaft spun backwards and came loose from the holding mount. When re installed it holds tight ,but when fired, it spins backwards and then it wont repeat firing. I re- assembled the shaft, cup, using Bearing & stud LOCK TITE.Waited over 24 hrs ,as directed on the package, fired 14 rounds. Works great. Lock Tite says it has the holding power of 3000psi. will see. If not, maybe a good gun smith. Thanks to all . PHIL
