Goose
I'm getting concerned about the oil pressure on my 1952 H Farmall. On a cold startup, it will hit 45 pounds. After warmup, it will barely move the needle at idle, and will hit 10 pounds at full throttle.
It doesn't smoke or burn oil otherwise. Good compression. It's possible the engine has never been opened up. The tractor has been in our family since 1958, and no one of us has ever gone into it.
I've replaced the guage and the oil pump, so those two suspects are eliminated.
Coupla questions. Are the cam bearings involved in developing oil pressure? Or are the rod and main bearings mostly responsible? And is it possible to replace the mains with the engine in the tractor? Or is anything else involved?
Thanks in advance.
Thanks in advance.
