O.T. - Truck question ( a bit long )
Billy NY
I have always been curious as to why so many truck drivers use their Jacob Engine Brake so much, especially when you don't need to, like on flat or non slope grades etc.
Habits I have noticed, since they are hauling across the street from the new TSC site, is some of these drivers will use it to downshift right to almost a standstill. Others just depend on it even just on the flat. Well I suppose the point of this paragraph, is overusing it detrimental to the engine in any way? Besides being annoying to those who live directly on the road, say like the guy who works nights LOL !
The other thing is late at night in towns, hamlets etc. whereas the homes that were built long ago are directly on the road, or within 50 feet, and some of these modern trucks have 6" ( I thought that was big ) or even 8" stacks and drivers use the full engine brake (I recall ones that had 3 stages) and rattle people out of their beds. One local town that I haul through has signs citing an ordinance making it unlawful to use a engine brake within the town limits, and based on the grade, there is no need to use one, or is my opinion. Also with the old 3 stage type, old timer to use all 3 at once, don't use 1 or 2, this was a long time ago, supposedly for even wear or some darned thing.
My experience is with both tractor trailer, tri-axle dump, and most kinds of trucks, spent many years driving when younger, and can recall driving trucks that did not have engine brakes, but also carried heavy loads like the long wheel base R model Mack I hauled flatbed loads of lumber with from the rail yard and industrial parks whereas I wished I had one, 300+ mack 9 spd fuller, and I can recall knowing how to feather those brakes to not over heat them on long downgrades, that is where I thought engine brake use was appropriate. One place I worked, had a 4300 International with a 400 cummins, 10 spd fuller that cavitated, we had the shop across the street rebuild it and install a 3 stage engine brake, it would practically toss you out of the seat, (manner of speaking, it was strong).
I've also tried using the engine brake when downshifting, it slows the rpms but all trucks are different, sometimes it does this too fast and you are locked out, fiddling to get back into a gear that will mesh. Mack R's, DM's with those old school, twin stick, 5 or 6 speed transmissions worked well doing this, though not necessary, seemed a lot of drivers did this for downshifting, be it a good habit or bad. I always tried to get used to the RPM range that worked well (spread)for shifting a particular truck and prided myself on learning same so shifting was smooth, some drivers could care less and abuse transmissions, though the engine brake is handy for it, is it bad practice to do so ?
I realize that in combination with your brakes, you save quite a bit of wear on same, and with some of the heavy loads I've hauled, it would seem unsafe not to have an engine brake, (30 tons of asphalt into a tri-axle for example is a big ole monkey on your back) We used to get some slack about weight on state road jobs when they needed them done, was even pulled over by a state trooper and in not so many words was told, just keep your mudflaps on, lights working and those brakes in order, all you have to worry about !
Trucks have changed quite a bit, I've driven quite a bit of the older models, like AutoCar, Mack, International, Freightliner, White, with all the varying engine and transmissions, not so much of modern ones, latest I think I drove was a '01 Freightliner.
What say you, good habit, what is overuse and what is correct use of an engine brake today or back then?
Many of the local towns on the nearby 4-lane (U.S. Highway 51) have signs at the city limits prohibiting their use.
I use it all the time. When you get used to it,it's hard to drive with out useing it. Must learn how to feather throtle for shifting. Three stage is best. I run mufflers & dont care much for the cowboys running 6 or 8" pipes trying to wake the dead!
(quoted from post at 11:13:20 08/16/11) I have always been curious as to why so many truck drivers use their Jacob Engine Brake so much, especially when you don't need to, like on flat or non slope grades etc.
The engine brake was designed to be used for controlling the speed of a truck while descending steep, long mountain roads. Any other use is strictly for showing off. "Hey, look at me, I've got a Jake brake!!"
And yes, I have put a few miles on an 18 wheeler driving coast to coast, and I really did appreciate that Jake brake while going through the Rockies.
In my life time I have owned and used a B61 and a B75 Macks,A 350 Diamond Reo and a K100 Kenworth Cab Over. Each and every one of them made countless trips over Vail Pass on old US6,McClure Pass out of Redstone Co. Wolf Creek Pass,Monarch Pass and others. None of these Tractors had Jake Brakes.Standard procedure when you got to the front range was a brake set up,Use the gears and engine to hold you back . Some of those Passes were a pucker up deal,especially in the winter but none of my drivers ever had an accident. Slow and sure and under control was routine.I think most of the use of the Jakes nowadays is a show off deal.True we only grossed 73,280lb's then and now they are grossing at least 80,000lbs and the use of the jake coming off a pass is justified,But,there is absolutely no reason too use one in a populated urban area.
To start with you are not supposed to use a Jake brake in the city limits.But for the drivers doing it on flat ground,a dump truck can get the brakes real hot,real quick.Its a little different than driving over the road where you are just running down the highway.In town,heavy load,lots of stops,driver thats not very good to start with in a lot of cases.Plus its an annoying noise.It scares people.Some guys get a kick out of that.
Most, if not all, of the cities and towns in this area have signs about a mile from the city limits sign saying, "Engine Braking Prohibited".
They can't say "Jake Brake" on the signs 'cause it identifies a brand name.
Using the Jake saves the regular brakes, so it's in the rig owner's best interest to use it.
My state the town can put up a sign limiting it's use.
As to agribvating, I understand.
a couple decades ago they put rumble strips on the tar road by the stop sign almost a mile away from me. I can hear every vehicle going over those rumbvble strips, no more peaceful evenings. There is a hose about 100 feet from those rumble strips. I woulda been really unhappy if I lived there when the strips went in..... Don't know how they tolerate them.
--->Paul
Yes, some get off on that noise, I hauled thoroughbred horses in a tractor trailer, and who is to say what the engine brake cause them to do, this was the '01 freightliner, much quieter, but I gradually introduced the use of it, one hill on the way out, the rest you really don't need it.
The tri-axle dump crowd seems to like to use the engine brake on the return trip empty on this job across the road, which is flat, I make the same turn into the same road, loaded and or empty with a DM mack and don't need the engine brake for any reason.
I would agree, on the local neighborhood use of these. We get a ton of truck traffic on the state road here, but I'm back 1/4 mile or so, but used to live right down on that road, I would be after the town to provide an ordinance and post signs, these drivers are rude at 3AM as I can hear it clearly sometimes.
I've driven B-61's with 5x4's in them, + the old late 60's early 70's AutoCar's, 230 cummins and 350 cummins, 13 spd, nothing but raw truck and you had to wear earplugs while driving those, I use to pull a heavy Rogers lowboy, all truck and nothing else.
The R model I drove hauling lumber, loads were excess of 80,000 lbs at times, I sometimes put a 3rd tier in the middle of the 2 high stacks, where there was no height issues, but just not on the highway, had local route from the rail yard, but the one route on the return trip had a pucker factor, you just used the appropriate gear to keep the speed lower and not over speed the engine.
It sure does save wear on the brakes!
However........everybody knows some guys just like the sound. Guys using it between shifts at very low speeds are (like someone else said) saying "look at me, I"ve got a jake brake"!
Somewhat akin to the sound of a flathead with glasspacks when you "throw her in second" just to hear her "back off"!!
That is the truth, ain"t it?
like daddy said.. you can wear out brakes or you can wear out the engine... you pick whats cheaper...
so unless your in the mountains... its all bs..
*&%^$#$ REDNECK MENTALITY and the worst offenders are driving the long nose 379 Peterbilts and w900 KW's without mufflers and using oversize straight pipes. Can you spell MEGAPHONES?? &*^%$% REDNECK TRUCK DRIVERS.
BTW: I drove 18 wheelers for 1.5 million miles.
I run through BillyNY's neighborhood everyday with an 08 Kenworth W900 (600hp Cummins 18 speed trans) hauling gasoline grossing 99,000 - 102,000 lbs. 2 loads a day back to NH over the mtns of VT. I run my jake brake all the time unless it's slippery. Just replaced the trailer brakes@ 350,000 miles on them, so any of you that think a jake is not necessary I beg to differ with you. It's also a saftey issue so I have more control stopping when some idiot pulls out in front of me. I do agree that some of these trucks are loud but so are motorcycles and no seems to complain about them. (I have stock exhaust)
(quoted from post at 14:44:00 08/16/11) like daddy said.. you can wear out brakes or you can wear out the engine... you pick whats cheaper...
ow does a jake wear out the engine when it stops it from firing? Wouldn't it have to be less wear?
I owned and operated a triaxle for two years. I read both engine and truck owners manuals closely, and did as they said which included using the jake! I always geared down for hills and for congested areas. In the lower gear the engine is turning faster so the jake is far more effective so it enhances your ability to compensate for another driver's lack of attention. I suppose one could feather the brakes going down hill to keep them from heating up but I don't think that those feathers will cushion you much when you run off the road because it gets steeper and then a sharp curve. I would rather be using the tools at my disposal to maintain control all the way after starting down much slower than I probably need to.
Got my Miles under me (and Plenty)...
I just figure any driver using a Jake while down shifting just about anywhere is just a dam?ed Rookie..
There are times, I agree that it may be good, not for the average stop in town...
I ran Coast-to-Coast for 10 years before we had our 1st Jake..NEVER used it if a Co-Driver was asleep in the Bunk..
Just Common Sense...!!
And YES, I am a Mountain and ALL-Weather driver.
Ron..
Have a question! I drove quite a few miles in rigs, no Jake brakes. What kind of brake control do you have for the trailer when the Jake is used? The tractor has the engine but not the trailer.
It's very irritating to me when some young cowboy with straightpipes jakes clear down to the last gear when empty on a level road. The message he is trying to get out is "look at me in my big truck". No wonder every town has engine brake signs.
The Jake brake slows down the tractor only. The trailer is just along for the ride when the Jake is used. The jake increases the engine's braking power by opening the exhaust valves just before the piston reaches TDC on compression stroke. That way there's very little compressed air left to push the piston back down. It's tricky because the exhaust valves have to be closed before the piston reaches TDC and they are timed so they close just fractions before TDC. Cat engines can eat valves if overreved with the jake on, like being in the wrong gear going down a mountain so the engine can't hold the load back. I tore one down that had been overreved and I found the valve heads from #1 cylinder in the oil pan. Jim
Where you are running and those hills is what its meant for. Fuel trucks out of the port of Albany, LPG trucks, are just about non stop by here, JP Noonan, Sandri, Champlain Oil Co. Barry Collins, and numerous others I can't recall at the moment,a very busy 2 lane Rt 7 is, used to be a bumper sticker out there, "Pray For Us, We Drive Rt. 7". I used to haul up into Manchester, Dorset etc. some of the mountain roads, dead of winter.
I use my Jake brake all of the time. I have a Cummins ISM motor with FACTORY exhaust. You can not hardly hear it. I have checked with the windows open it is real quiet.
I have three different semis that my sons are now driving hauling grain/feed. One does not have Jake brakes on it the brakes last only about forty thousand miles on it. The others get about 60K on them. ( We run gravel roads and have real steep deliver point at Clayton, Ia. Also 97,000 lbs legal loads, Brakes don"t last long)
For the guys running straight pipes on trucks or motorcycles. I think a $1000 dollar fine the first offense and surrender the vehicle the second would be just fine.
If you think that the loud exhaust is so cool, then bend them in a big U and point them in the window or right at your head!!!!! They have ruined sleeping with your windows open any more.
First off, I have got to say that anyone who says they are a "mountain trucker" that does not use the jakes, would not have a job long if the mechanic saw them, or when they drag into the yard a day or two behind the guy that used his jakes. Granted, I may be young, but I am used to real loads (up to 110,000 legally, seen upwards of 130,000 on off-road jobs) and real hills (%10-%12 on the highway, around %22 on off-road dirt jobs), and in those situations, you use the jake and whatever else you can think of.
Something nobody has mentioned, is shifting with the jakes when accelerating. When you are loaded heavy, going uphill, or on soft ground, using the jake to bring the RPM`s down faster between gears lets you shift faster and conserve momentum.
And on the maintanence side of it, jakes don`t harm the engine, and they save a lot of wear and tear on brakes and tires. There is not much money to be had owning a truck, less so when you tear things up you don`t need to. I guess what it comes down to for me, is that the old trucks went a lot of places with no jakes, but nowadays we don`t have the luxury to take our time, or the extra cash to spend money we don`t absolutely have to.
Using the engine brake will not wear out your engine. The pistons are going up and down, the valves are opening and closing regardless of wether you are using an engine brake or not.
Looking at it another way an engine that is operating at say 400 HP will only have maybe 300 HP of braking power using an engine brake. So when braking there is actually less force being exerted on the engine components than there is when it's being put under a full load in normal operation.
You can also look at it still another way. When you downshift the trasmission in a vehicle you are actually doing the same basic thing a true engine brake does. By that I mean your turning the engine into a large air compressor. In the case of downshifting the engine is being sped up due to the gearing and as a result is sucking in more air than it typically would at the same speed in any other situations. By taking your foot off the throttle the engine is doing nothing but compressing air and getting nothing in return because of the lack of fuel. With an engine brake it does the same thing by making the engine compress air without any power in return. The difference in what's happening, basically, is the Jake opens the exhaust valve and allows the setup to brake more efficiently than it would otherwise.
Ultimately the engine isn't gonna experience any more wear by using the Jake than it is not using it. The biggest thing you face with it is the tendancy for guys to shift down too far and overspeed the engine, and that's what's going to cause the damage. On the other hand the service brakes are going to wear every time you use them and every time you can use the engine brake instead your extending their life......But that's just the way I understand things based on both driving a truck with a Jake as well as having installed and worked on other trucks with them......
When I first got into trucking, in 1977, I was told that Jake brakes cut the crankshaft life by 1/3. It doesn"t seem to bother modern engines though. Not all engine brakes are Jacobs brand, Cummins makes a C-brake. It is very similar to Jacobs though, works the same way.
Yes, I would say the same for upshifting, all trucks are different, nothing worse than missing a gear with a heavy load on, engine brake gives you that window quickly before you lose momentum, definitely helps.
Jakes don't make much noise. Running without mufflers does. It is simply that we have a bunch of idiots out there. It's the "look at me, I gots me a big truck", last of the "American Cowboy" attitude. Nothing wrong with having some "pride in your ride", but the excess chrome, chicken lights, etc are big wastes of money. Keeping all that chrome looking presentable takes time that could be used earning income.
Shiny air cleaners on the outside look pretty to some, but they add wind resistance. If no room under the hood, tuck them behind the cab out of the wind stream. Shiny exhaust stacks are the same. They cost money to install, don't add to income, & you don't see the shinyness from the driver's seat. Engineers spend a lot of time & money doing wind tunnel tests to cut wind resistance, thus cutting fuel costs. Then owners do whatever they can to mess up the streamlining.
If you get a chance, look closely at the stickers on the edge of a door. Manufacturers for the last 20 or so years have to place a sticker that the vehicle meets EPA noise limits when built. Also there is a fine of up to $10,000 for modifying any noise limiting equipment. I always wonder how these drivers pass their annual federal inspection without mufflers.
Spent my working life on the road. Last boss speced out super duty mufflers. I very rarely turned off the Jake, only in slippery conditions, & then while looking for a place to park. Normally kept on stage 3. With good mufflers can't hear it, even with windows open. Boss regularly took tractors away at around 400,000 miles, take a new one, give the older units to rookies. Original brake shoes at turn in time inspection about 50%. Had a wheel seal go out on one, replace brakes on that axle, only brake repairs in well over 1, maybe 2 million miles.
While on a rant-chicken lights. They look nice from a distance, you don't see them from the driver's seat, & don't add to income. A study about 12-15 years ago showed that each additional, not required, light costs $500 over the life of the rig. Starting at installation- modified wire harnes & shop time, whether ordered new at the factory or owner installed. At inspection time, every light, required or accessory, has to be working. Have 1 or 2 burned out, scale ahead open, time lost waiting for your turn at shop, shop costs, delayed delivery, etc all add up.
As to using the Jake to slow the gears for shifting, a false idea. Learn to use the clutch brake the way it was designed. Make use of the clutch brake. Makes shifting quicker, quieter, & eliminates shock loads on drive line. Won't cause wear on clutch. Pushing clutch pedal about 1/4 inch or flexing your big toe on throttle cuts out the Jake. In over 40 years had only 1 clutch failure- rear oil seal on engine failed, soaked up the disk.
End of rant, time to do something else.
Willie, diesel pilot-retired
(quoted from post at 05:48:20 08/17/11) Jakes don't make much noise. Running without mufflers does. It is simply that we have a bunch of idiots out there. It's the "look at me, I gots me a big truck", last of the "American Cowboy" attitude. Nothing wrong with having some "pride in your ride", but the excess chrome, chicken lights, etc are big wastes of money. Keeping all that chrome looking presentable takes time that could be used earning income.
I agree on some of your points, certainly not on others. I don`t have much use for chicken lights, though up here they do have one use, and that is identifying who`s truck you are looking at. There are still few enough drivers up here that having a unique light setup lets people know right off whos who. As for external air cleaners, having them out from under the hood makes maintanence easier, allows larger elements, and dual cleaners gives you that much more element. I don`t like trucks without mufflers, but I like them as part of the stack. The great big new mufflers under the cab/sleeper make servicing the truck a pain, get beat to death by rocks, and put twice as much flex pipe (common failure point) in the system. Same objection to having the stacks out behind the sleeper. And setup that way, a truck can be nice and quiet, the W900 KW I used to drive, the turbo spooled up on a hill was louder than the jakes going down the other side.... And using the jake to slow gears doesn`t work well, it is the engine you are slowing down when you jake-shift. Getting into the gear is still going to shock load the driveline when you let the clutch out if the engine is a couple hundred RPM above the input shaft.
Saying that shifting with the clutch is easier on the truck holds true when dealing with fleet trucks and rookies, but if you know your truck it can be shifted very smooth without the clutch, and if you spend much time in a Westen Star ( my current, and preferred, make) you will not be using the clutch if you can help it because of the way the linkage is mounted between the cab and frame, torque twist makes them a handfull.
Edit to say: Many of my reasons listed only apply to off road, or gravel and dirt road situations, so may not be nearly so valid for a truck that spends its life on asphalt. In Alaska, even our asphalt is rough and dirty, and in the winter so much sand is spread on the roads that it will sandblast the undersides of a truck.
Sure using the clutch brake is good practice, for OTR hauling but for dump and many other vocational uses it is just not realistic unless you have a bionic left leg.
clutch brake is not for stopping or slowing the rig!
the clutch brake is only for slowing the imput shaft of the trany to facilitate the shift. I found that I use the jake to save the brakes for the times that some idiot plants it in front of me.
Tim in OR
