Deutz D4506
Joe in Mart
New User
I have a Deutz D4506. I have bent the PTO shaft, but I cannot tell whether or not it is bent beyond just the "spline" end coming out of the tractor.
If I pull of the cover plate will the PTO shaft just slide out?
Thank you,
According to the Spare Parts Manual I have, there is a circlip on the other end of the PTO shaft there is a gear that appears to be larger than the hole that the cover opens up. I can"t tell if there is an inspection cover on the side or not? It definately does not appear that the shaft will simply come out....
