OT-Brake bleeders
tomturkey
Is there a secret to getting them loose??? I know they recieve the brunt of salt snow water and dirt. Add some rust and they just don't wanna move. Is there a secret weapon to use? Just did not want to go thru the whole removal process to replace wheel cylinder when I just need the bleeder to work. Almost enough to make me quit wrenchin on my stuff. gobble
You can generally get them loose if you heat them just a bit with an acetylene torch. But beware: when the bleeder opens it will spew out very hot brake fluid, and it will give you a good burn if it hits you.
Animpact driver will probably work if you can get one onto the bleeder.
Use anti sieze once you get them loose.
I always anti sieze all bleeders when installing new cylinders.
Dean
Ive found that bleeders ususlly are a pain to get loose. Like was said before, heat them with a acc. torch.A trick I was told years ago is whenever you heat anything like this ,its better to heat around the base of the bleeder and not concentrate on the bleeder itself. Heat it good once and then let it cool,then heat again before trying to break it free.the heating and cooling will make the bleeder loosen easer.Then put just a small ammount of pressure on the bleeder using a 6 point box wrench or a 6 point socket working back and forth to free the bleeder.If your lucky enough to get it loose,then we put anti- seize on it to help prevent further problems.maybe not the best way,Im sure a lot of people have different methods but this works well for us.If you have a couple of extra days ,you can try PB Blaster. Im sold on that product too.
If you resort to a torch and heat the surrounding area hot enough to loosen the bleeder, BE PREPARED to blow that brake hose. It'll probably sound like a firecracker. I used to use a propane torch and the first and only time with my head under the fenderwell. When the hose blows you'll crease your head with the inside of the fenderwell. Bleeders, especially the smaller 5/16, don't work too well with too much heat. Try tapping on the bleeder with a small ball pien hammer similar to knocking hard on a wooden door. Soak it with penetrating oil and bee patient. Hope this helps. Gerard
I have had to bleed by loosening the hose. I know you do not get all of the air but it helps and the air will finally work out. I only did this on my own old trucks.
I keep bleeders covered with grease.Same thing for brake line connections.Grease can be wiped off.Just took the box off my truck to put on new spring hangers .A hydraulic line I replaced 4 years ago still had grease on the coupling.
(quoted from post at 17:23:44 08/09/11) Is there a secret to getting them loose??? I know they recieve the brunt of salt snow water and dirt. Add some rust and they just don't wanna move. Is there a secret weapon to use? Just did not want to go thru the whole removal process to replace wheel cylinder when I just need the bleeder to work. Almost enough to make me quit wrenchin on my stuff. gobble
The best cure is to simply replace the slave cylinder. Consider the safety of yourself, your family, and the other folks out on the road. If that bleeder screw is rusted in that badly, the rest of the brake cylinder is already compromised. THINK SAFETY FIRST!!!
