6 Way adjustor doesn't work. I measure 8.5 VDC at connector under the seat. Circuit breaker is good - to be sure I swapped a known good one with it and no change. 12VDC at circuit breaker.
Schematic shows a splice between circuit breaker and the underseat connector. Haven't checked that splice. Could it have built up a resistance to drop some voltage? There also is a multi-pin connector in the path which I haven't investigated - maybe that has some corrosion. Anyone have other ideas to try?
