Mike Henry
Looking for advice on pulling a mag from the tractor.Never done it and dont want to mess something up cause its on a friends tractor. We are mostly possitive that the coil is weak in it. We can start the tractor and it will run great for 20 min. or so doing whatever then it will quit and not restart. I have been through the fuel system(cleaned tank and line,checked and even traded out carbs, and new sediment ball system. Air flow is great at the carb,choke is working properly.
I dont know if there is something Im suppose to mark to make sure things stay in time or any other things I should know. Thanks for your help in advance. Please and thank you.
