8n 1950 axel bearings
Front or rear?
If front, the wheel bearings MAY be out of grease/full of grit and wearing out.
If REAR, the splines on the axle shaft and inside the hub are loose/worn, usually the hub wears more than the axle 'cause it's softer.
For the MOST help/ideas, surf over to the "N"-specific board linked below:
N
