Front rims for 1970 4020
Tominwi
What is the correct rims for my 4020? I have two different ones on there now. One looks like it has a deep style bead seat for the tire on the outer side of rim, while the other has the same seat, it is just on the inside. Any help?
Its kinda up to you.they came new with 7,50x15 tires.but you can put on whatever you like.7.50x16 is good.but a 9.5Lx15 would look SHARP!
What size rear tires do you have? If you have 18.4X34's then 9.5L 15's look great some people use 10.00 16's. If you have 18.4 X38 consider 11.5L X 15.Some 4020's came with 7.50X20 front tires. If you have 15.5X38 rears 7.5LX15 are ok.Narrow fronts used alot of 6.50X16 or 7.5L X15's.
4000 and 4020 (s.n. 201,000- ) Tractors
JD1091 WHEEL 1 (SUB AN241667) (7.50X15",6-PLY TIRE) (ROW-CROP WITH DOUBLE KNUCKLE,HEAVY-DUTY ROLL-O-MATIC AND ADJUSTABLE TREAD FRONT AXLE)
JD1299 WHEEL 1 (6.00X16",6-PLY TIRE) (ROW-CROP WITH DOUBLE KNUCKLE,REGULAR OR HEAVY-DUTY ROLL-O-MATIC AND ADJUSTABLE TREAD FRONT AXLE)
JD3211 WHEEL 1 (7.50X18",6-PLY TIRE) (ROW-CROP WITH ADJUSTABLE TREAD FRONT AXLE AND STANDARD WITH ADJUSTABLE OR FIXED TREAD FRONT AXLE)
JD3210 WHEEL 1 (9.00X16",10.00X16" OR 11.00X16",8-PLY TIRE) (ROW-CROP AND STANDARD)
JD3039 WHEEL 1 (7.50X16",6-PLY TIRE) (ROW-CROP WITH HEAVY-DUTY ROLL-O-MATIC AND ADJUSTABLE TREAD FRONT AXLE) (SUB FOR JD1293)
JD1290 WHEEL 1 (A) (SUB JD1291)
Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
JD3227 RIM 1 (7.50X20",6-PLY TIRE) (HI-CROP) (SUB FOR JD1298)
JD3219 RIM 1 (11.00L-15", 6-PLY TIRE)
