I have a MF 20C industrial. I added rear remote Hydraulic ports by puting a Hydraulic Selector, isolator assembly in place of the standpipe cover cap. After I got everthing bolted back together I had No 3 point lifting or remote flow, so I took the Hydraulic Selector, isolator assembly off and put the original cover cap back on and now I still do not have any lift. The Trans/Hydraulic fluid is new and full. I have removed and replaced the rubber O-Rings, tripple checked standpipe placement and still nothing. Everything was working prior to the initial selector valve instalation.
Thanks for any Ideas,
Jake
Central NY
Jake
Central NY
