1934 model A
Tominwi
Can anyone tell me what this tractor is worth? It is a JD 1934 model A. Not restored just out of shed, cutoffs front and rear. runs good.
The big thing to determin value is, is it one of the earlier models with the open fan shaft or a later 1934 with a closed fan shaft. Open will about double value of tractor, wheels on a open shaft model would not make much difference unless they were still the steel and not cut down.
Like any tractor it starts with is it complete? General condition? Where is it? Etc.
As Leroy referred to, there are a lot of unique parts on the 34 As that can make a big difference in the value starting with the tag, serial number, the open fan shaft, seat pedestal, brakes and etc. A lot of these old tractors have had a lot of the original hard to find parts torn up, worn out, swapped out and that will diminish it's collector value considerably.
(quoted from post at 16:22:18 07/20/11) Has open fanshaft, brass tag, flat cuts on rear, fronts cut, ser# 410063
Well, The SN means it's an early GPA and that increases it's value quite a bit. Some others here can give you better guidance on the value of these but it is definitely a sought after collectible.
