what are they called and where (online) can I find them??
Anonymous-0
Lost a keeper pin on the foot (stand) for the drum mower and bent the leg when it drug the ground. Got it straight but need a pin. just don't know what they are called to look it up. This one is about 1/4 inch thick, shaped like a hairpin and isabout 8 inches long.
Thanks, Dave
Dave I would get the same type as you use in your three point lift pins. The kind with the ring that flip over the pin. They are called linch pins. They make them in different pin sizes and they are much easier to use. Plus weed/grass are less likely to pull them out.
1/4 linch pin Shoup catalog
