mf 50 3 point hitch
Paul Gundrum
New User
Short version - picked up a MF 50 gas runs fine , except three point wont lift. Previous owner said all it needed was a pin that was easy to replace. Dubious but snapped up tractor anyway. Can't find anything in manual about a "pin". Owner seemed to think it was a common problem. Any suggestions much appreciated
Does the pto work?
Not a "pin", but a coupler inside the rear end. Not exactly a "nuthin' to it" sort of repair...Seller might have been a bit confused...
He could mean the pin that the 3pt. linkage connects to. The one you need to make sure to disconnect before pulling the top cover off (at least on a 100 series). Not sure if the earlier models use the same set up.
Thanks for quick response. PTO works fine. Seller may have just wanted to get rid of tractor. While I don't "need" the 3 point I would like to fix it. Any further advice?
