Anonymous-0
How well will a Bondioli & Pavesi 100 Series: Size 6, PTO shaft hold up on a Bush Hog Model 406? I will be running the bush hog behind a Farmall 656 or 806. Would I be better off with one of the orginal PTO shafts for the 406?
Bondioli & Pavesi 6 is rated at 64 hp @540 and 100 hp @1000. It is listed as the replacement shaft size for a 7 foot 3 point rotary cutter. With shear bolt or slip clutch protection you should be good to go.
Bob
