Ford F350 Replacement Coil Springs
wilamayb
I've looked all sorts of places for replacement coil springs for the front of my 1967 Ford F350. I have been unsuccessful so far.
I've tried the obvious outlets. Most only offer parts for the half and 3/4 ton.
Any suggestions? The springs sag badly with the gas engine and will be even worse when I install the diesel.
Maybe try some off of a newer F350 or F250 You could get light duty f250 which had coil springs. I would try some off of a 1986 f250 with a diesel engine. Or if you got a junk yard close by maybe look at some trucks with coil springs in front.
if i remember rite '65- 79 were all pretty dang close...wern't many diesel pu's back in them days but the 460 springs should have enuff weight limit...when building wreckers for the shop i worked for we even put dual coil over shocks on front and rear...air bags inside the coils is another option but theyre pricy.
just for s&g's check with jc whitney...they useta have all kinda neat parts to modify trucks.
I needed set for a heavy 3/4 ton Ford and they were only available from Ford(that was 30 years ago)Light 3/4 and 1/2 ton any where.
