Anonymous-0
Hey folks,
need a trick or better solution to what I'm doing.
Have several 12volt fence chargers that I use and need to charge the batteries. Have a little auto charger that can be set to normal or trickle and shuts itself offwhen charged. Sometimes I forget to swap batteries before they are completely empty and the charger won't recognize that it is hooked up to a battery. Can make it work by running jumper cables to a good battery for a few minutes til it gets a little juice in it but then have to charge the other battery again also.
Would a normal charger just kick in and charge the battery empty or not? Or would it have the same problem?
Thanks, Dave
Thanks, Dave
