Case CK 430 Power Steering Pump Problems
Hobo2u
New User
I have a Case CK 430 and I have a problem with the power steering. The Case ck 430 has a gas engine and the power steering is under the generator and has 3 bolts holds it on. I took it off and it has a sheared pin. The roller bearing are missing .Can the parts be purchased and if they can where can I get the parts? If I I need to find another pump. Does anyone know where I can get one for a reasonable price? Thank you for any help you can give me.
It would help if we knew if the pump was
original to Case, or an aftermarket or junk yard
add on. There are advertisers in "Hemmings
Motor News" magazine that advertise parts for
just about any power steering pump. That magazine
is for old car and truck restorers.
The most common pumps were "Saginaw"(a division
of GM, but also used on Chrysler and IH)"Eaton",
and "Ross".The largest Mfr of Hydraulic pumps in
the World,"Vickers" has an extensive line of
Industrial power steering pumps, used in Fork
Lifts, Farm, and Off road Industrial equipment.
If your Case dealer can't help, and you take the
pump off, look for some type of name or Logo!
The pump has a BD on it .On the part of the pump that goes into the block it has these numbers C452231 .It also has other number on the pump looks like Gc 27 29 . It would be alot cheaper if I can find parts.
Thanks
There was a Barnes Company that made pumps for CASE. Search the CASE site and maybe some thing might be in the archives.
