old
- Location
- Camdenton Missouri
Well some of you know my heat pump went out this winter had to have a new compressor put in at a tune of around $700 and that was under warranty to boot. So then had it rechecked 9 days ago because it doesn't seem to keep the house as cool as it should as in if I set it at 72 I'm lucky if it stays 74 or so in here. But then after dark I have to reset it or you freeze and it if set at 72 will cool it down to 70 before it shuts off. Well today the wife says is it hot in here or is it me. I go and check and sure enough it is 76 in the house and the unit is working but not cooling much. Checked the A coil and one side is froze up all the way and the other side part way. Check the cool line coming into the house and it has ice covering it but yet 9 days ago the guy could not find any thing wrong and charged me $86 for not finding a thing what has happened to good service theses days
