Engaged started
Pigman
New User
I have a MF 1080 that the started stays engaged. I have replaced the starter and the new one does the same thing. I have even shimmed the stater thinking it was engaging too far but it stays engaged to the ring gear. Any help would be appreciated.
Thanks
Bad wiring or switch. Run a jumper to the solenoid/relay to bypass the ignition and see if it cranks and stops cranking. If so it is not the starter assembly. Jim
