Anonymous-0
A person I know went down to the States to take a coarse on making gas motors run on diesel. I have not seen him to see how he made out. Has anybody ever heard of this?
believe they took the 350 and put diesel heads on them, I believe this is something different and Im not sure what. I thought maybe some one on here might know(quoted from post at 03:46:45 06/13/11) Didn't GM do that back in the 70's? I don't believe it worked out to well.
(quoted from post at 08:06:09 06/13/11) The last year or two of the Olds diesel adventure. The bean counters relented and let the engineers build the engine that way they originally designed it.
High allow block, roller cam etc. Good engine but the power was low and the reputation was tainted.
The diesel owners of that era didn't do the Olds engines any good either. Many so called failures were due to the lack of oil changes.And dim witted owners putting gasoline in the tank.
(quoted from post at 05:34:53 06/13/11) Can you give examples of direct injection gas engines? Thank you
(quoted from post at 13:30:59 06/13/11) I mean which makes and models of cars are running them. I know certain ford cars are but research says that they to have to run a turbo to get the power and economy.
