diesel pops out exhaust?
mmidlam
what can cause a 4 cylinder diesel tractor to pop flames out the exhaust at higher RPM. Sounds ok at a slower RPM. Too much fuel and a exhaust valve not seating?
Good call Doug, I'm with you. Many times the 188 Case diesels will do the same thing because the transfer pump pressure is what advances the timing. A weak transfer pump will supply fuel to run but not enough to advance the timing. As a stopgap many times I have loosened the pump and manually advanced the timing running till the miss cleared and locked 'er down.
Doug, whats up, give me a call. mEl
