Hydraulic Manifold Block
David G
I need to make a hydraulic manifold to mount on a pump. It is about 2" thick x 4" wide x 3" high. There are three 3/8 bolts that hold it to the pump. I will drill and tap NPT female holes in the block to mount hoses.
The question is will aluminum work for that, or do I need steel.
Thanks,
You'd probably need a specific grade of heat treated aluminum but since some hyd. pumps are aluminum, it should work.
