1948 Case VAO
Anonymous-0
Can anyone tell me what fluid is supposed to be used in hydralic 3 point lift pump? I drained it and went back with regular hydralic fluid and the 3 point has not worked since i have done this. Should i have used transmission fluid or what? Also in the transmission i used 80-90 gear oil. Have i done correctely here or should i have used a lighter oil? I appreciate any help i can get. Thank You Wayne This is in a 1948 Case VAO Tractor
Yes i know where bleeder is and have bleed it several times and still have had no luck in getting it to operate. Thank You for your reply.
