threaded nut
Anonymous-0
don;t know where to look to get one ,, farmhand wheel rake has a stripped nut on the lift mexhanism ,, very coarse thread typical of cranks on old pull type 8 ft tandem discs ,, is farmhand under the agco flag now >?
(quoted from post at 04:15:48 06/06/11) don;t know where to look to get one ,, farmhand wheel rake has a stripped nut on the lift mexhanism ,, very coarse thread typical of cranks on old pull type 8 ft tandem discs ,, is farmhand under the agco flag now >?
If the dealer option does not pan out: Any chance the threads are ACME threads? If so places like McMaster Carr, MSC industrial supply, or Graningers might have something that you can make work.
I have an Oliver (Darf) which is very similar. When mine stripped I made a new screw from threaded rod and a xommon nut to fit. Welded all together and has worked for several years.
Back when I worked for a JD dealer we used a split nut that had another nut screwed on the outside of the split nut that clamped first nut tighter to put on frt axle spindle bolts that the threads were bad. The nut has a name but I can't recall it. A lot of Ford 8N frt spindles used them.
