Cockshut 30 rear tires - question
Anonymous-0
I am looking for a set of used tires for my Cockshutt 30 which is still a solid working tractor. I found a good set that are 12.4-38 Will they fit my Cockshutt 30 ? The Cockshutt 30 currently has 11.2-38 I was wondering if the bigger tires would rub against the fenders or anything like that.
(quoted from post at 06:02:04 06/02/11) I am looking for a set of used tires for my Cockshutt 30 which is still a solid working tractor. I found a good set that are 12.4-38 Will they fit my Cockshutt 30 ? The Cockshutt 30 currently has 11.2-38 I was wondering if the bigger tires would rub against the fenders or anything like that.
The 12.4 MIGHT stand up a little taller than the 11.2, but they are basically the same tire. I'm not that familiar with a Cockshutt, but I can't imagine there would be any fender clearance issues.
if memory is correct, original size was 10-38 standard, optional size 11-38. and replacement sizes with new numbering system would be 11.2 and 12.4- 38
