Whats the tallest tires I can use?
I have a Allis Chalmers "C" that has 24" wheels. They are 8" wide. I use this tractor for tractor rides and need the speed. Its not used for field work anymore so the reducing of torque wont be an issue. I want the tallest tire I can get for it. I know when it comes to tractor tires I cant get taller without getting wider also. So whats the tallest/widest tire that will fit on my wheels? Now it has 9.5 - 24
maybe the best thing to do is talk to a tire store to see what is available if you are going fast watch out for fiestoneLOL
Probably 11.2-24 is about as big as you'd want to go. Anything bigger is going to look out of place and won't fit well on an 8" rim.
Justin check with your local salvage yard, I think there are some rims off a combine with 13.6X26 on them that will bolt on to your final drives
